Custom Mode could not disarm Arlo using IFTTT
  • 4 Replies
  • 4296 Views
JC3328
Hi There,
I have a simple Arlo Pro 2 2-camera system, I would like to create a custom mode to disarm the system but have one of the camera still detecting motion. However, I have failed to disarm the system, and the siren will sound everytime a motion is detected.
I have set it to do nothing after detecting motion (including the base station...) but it still set off the siren.
Any clue?
Dannybear
So to confirm, you want to have one camera always detecting motion and or sound and to trigger the siren. The other camera set for no action but still viewable with live view. Correct?
The simple approach would be to remove the unwanted camera rule in the armed mode. Then switch between armed and disarmed as required.
As mentioned above....
Any camera NOT in the active mode is OFF
If the system is still acting glitchy, first try a power button reboot of the base.
If still NG, then I would remove the devices and bring back as new.... this will rebuild all the default modes in the system
JC3328
No... I should have made myself clearer.
I am trying to use the motion detection to trigger a IFTTT command.
So I have 2 camera, one called entrance and one called lounge. I am using geofencing to trigger away and home mode.
Away mode it will get it Armed. With motion detection and siren if detected anything on both camera.
I am trying to create a custom mode for for home mode, I want both camera to be disarm ( no siren triggered) however, the entrance remain the motion detection which I could use to trigger a IFTTT command.
What happen now is that it trigger the IFTTT command with no issue, but set off my siren at the same time.
Any clue?
Dannybear
So in your custom mode rules you do not have the siren device added?
If you do you can delete it. If not you can add it in and disable it to see if it fixes the issue.
