- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Configured Arlo Pro 2 and Echo Dot 3 for Alexa...
I have configured my Arlo Pro 2 system and the Amazon Echo DOT 3, downloaded the skills and tried to configure motion with the following link.
When I go to choose smart home, it says there is no smart home devices. I have configured the cameras and chose to enable voice , and have alexa say "movement at door" everything seems to be configured correctly, but when there is motion on any of the Arlo Cameras, Alexa does not tell me anything. ( i have even told it what speaker to say it on ). If I run the routine test it does work however, and Alexa says "movement..."
Any ideas why I cant get it to fire correctly?
Keep trying to pair it. It just magically paired with me after about 10 back-to-back attempts.
Here are the steps I used:
1. Download the Arlo App on your phone
2. Turn on cameras
3. Complete software configuration in Arlo App on phone
4. Open Alexa App on phone
5. Download Arlo skill in Alexa
6. Sign in to Arlo account in Arlo skill in Alexa
7. Keep trying to locate smart devices in Alexa app on phone
8. Tell one of your Alexa visual devices to “Activate Arlo”
If you have a Firestick or some such, I told my Firestick to “Activate Arlo” and then it told me that Arlo was already activated.
Only then was I able to locate the cameras.
Your visual Alexa will only show the cameras. I named my cameras “Front Door” and “Back Door,” so when I tell my FireTV to show me the “Front Door,” it will show me the Front Door.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
