Can’t connect to Google Home
  • 2295 Views
Morgandanielle
I have tried using both the Google Home App and the Google Assistant App but when I add device and select Arlo I first get a notification “Arlo is Linked” then a spinning circle then it stops and says “Something went wrong, try again.” I just have tried this 100 times now. Anyone had success working through this?
ShayneS
Hi @Morgandanielle
Are you still experiencing this issue with you system & Google?
Morgandanielle
@ShayneS Yes I am
ShayneS
Hi @Morgandanielle
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
