Arlo pro with Smartthings multipurpose sensors
  • 4 Replies
  • 5191 Views
  • 2 Likes
trayes77
I am interested in purchasing a Smartthings hub but I want to see if I could use a Smartthings sensor on my front door to activate the base station siren. This way I can use the siren that way rather than having to set it to go off when the camera senses motion. Can anyone confirm whether or not the door sensor can be used with the siren?
trayes77,
I have not tested specifically what you are describing however you can find more information on Smartthings integration here:
How do I integrate my Arlo Wire-Free cameras into the Samsung SmartThings app?
What is Samsung SmartThings, and how do I use it with my Arlo cameras?
It may also be useful to take a look at the Smartthings community to see if anyone with Smartthings sensors has made this work: Smartthings Community
trayes77
Thank you for the information. I've checked the Smartthings forums and have not found an answer. The provided links also do not provide a clear answer. If hope anyone with Smarthings integration sees this post.
Peterdgreco
Hi trayes77, have you found the answer to this. I own an Arlo Pro system, a smartthings hub and a smarttings door sensor. I too want the base station siren to turn on when the door is opened (likely by an intruder)
trayes77
Unfortunately I have not found an answer. I have no desire to purchase the Samsung system only to test it out. Please let us know if you find an answer. Thanks
