  • 10 Replies
  • 2206 Views
JAAS
I have 2 base stations 1 has all Pro 4 cameras the other has a mix. The one with all pro 4 cameras (vmbn5000r5) works the other (VMB4540R2) connects for 30 sec's and stops. If I unplug it, then plug it back in, it works again for 30 sec's then stops. All worked before Apple did the Homekit Matter update, so why is this happening.
FYI all work in the Arlo app no problem, all have the latest firmware as does my phone.  Again the Matter update appears to have messed up a lot of stuff - how do i fix this? FYI I have tried all std. stuff, removed and added back to Homekit recycled, power, even reset and added all my cameras back to the base station then to Homekit, same results.
10 REPLIES 10
ShayneS
Hi @JAAS
If I am reading this correctly, the VMB5000 has no issue via Homekit and live streaming?
The VMB4540 let's you live stream cameras for 30 seconds before they stop?
Is this correct?
JAAS
To be exact the 5000 works in HomeKit and shows live streaming on all cameras, the other 4540 all show not responding yet all work in the Arlo app and all worked prior to the Matter update from Apple.
All have latest updates, base and cameras
VMB5000 Series has 3 Arlo Pro 4 cameras – no issues
VMB4540 Series has 4 Pro (originals)  , 2 Pro 2 and 1 Pro 4 on it none work
It is like HomeKit only recognizes 1 base station now?
Thanks?
Jeff
ShayneS
Thanks for the clarification. Do you also have the latest version of the Arlo iOS app 4.6.1?
JAAS
This version of software is not on apple yet as i try to do update daily so all latest is on my phone. My system says I have 4.5(6272)  there is no 4.6 available.
ShayneS
@JAAS Can you remove and reinstall the app to force the update through the App Store.
JAAS
I found it in the developer section and loaded it - however Arlo app always worked well with both base stations. The 4540 bridge says not responding in Homekit but the 5000 does work.
ShayneS
And the issue still remains with the latest version?
JAAS
No change...  unless the updated Arlo app updates Homekit I would not expect a change.
Old Arlo ver and the new both are working perfectly - when the 500 shows in home kit as does the 4540 but 4540 says not responding..
ShayneS
Thanks for that, I have notified the team and I will provide more updates as soon as possible.
JAAS
Team, this is not getting to be too much and my home security is at risk. I need an answer or I will have to look into switching to Ring or Eufy as they are not having these issues. (my daughter is getting bullied and I need these working)
Why is one base working and the other does not, very odd. As I said the second base works for 3 to 5 min then goes to not responding... I have done everything requested and still it is not working, this includes a complete factory reset. The only reason i bought these was for the Homekit integration. Please help!
