- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Arlo connected to Amazon Echo Show 8 - how to ...
I was able to sync my Arlo with my Amazon Alexa Show 8 with no issues.
Question: When I ask Alexa to view a specific camera on the Amazon Echo Show screen, sometimes it is in full screen and sometimes it is in Picture in Picture.
Is there a way to make the default view always full screen?
Please let me know.
Thanks!
Hi @lgbalfa
When did this symptom first occur?
May I ask which troubleshooting steps you have tried so far? I don't want to suggest anything you have previously performed.
I just noticed it on my new replacement device.
All I did so far was a factory reset and it still did the same.
Is this normal to have picture in picture as default and not full screen?
I'm inquiring with the appropriate team to try and find the correct limitations. I'll update you as soon as I have more info.
The Arlo development team is currently investigating reports of this behavior. We will provide an update as soon as we have more information to share with the community.
Please advise on how to update the firmware.
How to Check Firmware on Echo Show 8
Swipe down from the top of the screen.
Tap the Settings gear icon.
Scroll down and tap Device Options.
Tap About.
Look for Device Software Version — this is your firmware version.
Echo Show devices update automatically, but you can help ensure it’s current:
Keep it plugged in and connected to Wi-Fi.
Leave it idle for a while, especially overnight.
Optionally, reboot the device by unplugging it for 30 seconds, then plugging it back in.
There’s no manual update button, but sometimes saying: "Alexa, check for software updates." can trigger a check (though she may just say it's up to date).
The device software is current.
I think it's possible that this is just normal.
AppleTV
31 -
Samsung SmartThings
81 -
Security System
