Arlo baby disconnects from Alexa echo spot
  • 1 Reply
  • 1021 Views
docbrog
Hello. My Arlo baby works and is visible in echo spot but continually disconnects and I have to repeat the command. Which can be the problem? WiFi signal is enough strong. Thank you
JessicaP
Hey docbrog,
Are you still experiencing this issue? If so, have you tried rebooting your Alexa Echo Spot to see if that helps? Otherwise, try to disable and re-enable the Alexa skill if you're having problems with the live stream not working properly.
