Arlo and Google Home
When will Arlo be able to interface with Google Home????
Arlo does interface nicely with Samsung SmartThings...which does interface with Google Home. Just an idea.
I don't have a smartthings hub. Can Arlo connect directly to Google Home without the hub? I don't see the option. Can you provide details?
Thanks, Jim
You need an intermediary device/service that they can communcate to and through. If not a SmartThings type hub, you may want to look into using IFTTT. That service may be able to do what you are looking for via 'All Internet'.
You can look here to see what is currently compatible with Google Home:
https://madeby.google.com/home/services/
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
