Arlo Ultra Homekit
  • 14 Replies
  • 7825 Views
  • 5 Likes
  • 7 In Conversation
Isacksenfamily
Recent Firmware upgrade to Ultra SmartHub VMB5000   caused HomeKit video integration failure.  Has anyone had a similar issue?
Isacksenfamily
My firmware appears to have been updated (version 1.21.1.0_1431_9611cf3) and now I can view my Arlo devices by Apple HomeKit.  Thanks.
14 REPLIES 14
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Isacksenfamily
I went though the documented reset process; however, HomeKit on my hub was still present and the cameras associated to the hub are still not connecting to HomeKit.  Any ideas?  This behavior just started with the latest firmware update today/yesterday.  Version is 1.21.1.0_1429_898b168.
Beast
I also have this same issue - started this morning.
The development team is currently investigating these reports. I will provide an update as soon as I have more information available to share.
JP_13
I really do hope that this firmware update fixes the corrupted SD card bug, but unfortunately it broke my HomeKit connection. I’ve reset back to factory settings and tried everything that I can think of. Can you please reset my HomeKit token?!
cb_blargh
I am also having this issue.
MORGiON666
Isacksenfamily
@JamesC , any update on the firmware bug fix?
The development team is continuing to investigate reports of HomeKit not working with VMB5000 SmartHubs. We do not advise any troubleshooting on your part to attempt to resolve this issue at this time.
You can keep updated on this issue at status.arlo.com
We apologize for any inconvenience this has caused and are continuing to work diligently toward a solution.
cb_blargh
JamesC — thanks for the info!
The ticket is marked as resolved, but there are no instructions on how to implement the fix (mine is still broken).
Do you know how we apply it?
Isacksenfamily
cb_blargh
I have the same firmware version, but the Arlo app doesn’t find any devices on the HomeKit discovery page. It just spins.
I’m wondering if I need to reset the base station to fix it.
Chuck-cheese_08
Same here. Tried turning off and unplugging power for a few minutes and letting it re-boot. No luck either.
cb_blargh
I performed a hard reset, re-added my cameras, and was then able to re-add it using the Apple Home app.
