Arlo Pro fails to reset "Motion detected" to SmartThings hub
  • 1552 Views
vicz
I have several Arlo Pro cameras integrated with SmartThings, and I use "Motion detected" as a trigger to turn on some lights. Recently I notice that after there's no motion, the cameras stuck in "Motion detected" for a very long time then reset to "No motion" status. If the cameras is in "Motion detected" mode, and if there's new activity, a new automation won't be triggered.
Am I the only one having this issue?
ShayneS
May I ask which troubleshooting steps you have performed so far? I don't want to suggest anything you have previously performed.
vicz
Thanks for the reply. I only tried to turned off the camera via app then turned it back on.
vicz
To be more specific, only turning off / on via SmartThings app can reset "Motion detected" status, but it's not working by using Arlo app. "Motion detected" status will be reset back to "No motion" in 1-3 hours, however that basically makes some of my routines useless. Thanks.
