- English
- Arlo Forum Discussions
- Partner Integrations
- Arlo Pro 2 won't connect to my Smartthings hub
I can not get my Arlo Pro 2 to connect with my smartthings hub. What can I do?
Firstly, are you using the Smartthings Classic app or the newer one. I only use the Classic app. In the Marketplace there should be a Arlo Connect Smart app. Have you tried this? Or you can go to the Cameras section of the Marketplace and add them there.
Brian
AppleTV
33 -
Samsung SmartThings
88 -
Security System
