Im having trouble with my ifttt-Arlo integration. Ifttt tells me that my trigger fail with the errormessage «Request body is missing» on random checks. Sometimes it works for an hour before the message shows again.
We released a fix to resolve this. You shouldn't need to change anything on your side. Your IFTTT applets should start working normally again. If you still see the error, please try this:
- Open IFTTT and go to the Arlo service.
- Disconnect the Arlo service, then connect it again and sign in with your Arlo account.
- Turn your applets back on if they were paused.
If the problem continues after that, reply here with roughly when the error happened and we'll look into it further.
Thanks for your patience!
Hi @Hsolli
Thank you for the feedback. The team is working on a fix to resolve this issue. I'll provide another update as soon as possible.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
