I made the mistake of removing my Arlo base station from HomeKit and now stuck trying to reconnect it to HomeKit, how do i fix this?
Hi aloths and Spalazzi,
I've sent a token reset request to your Base Station/SmartHub that should resolve the issue. Please reboot your Base Station/SmartHub (remove and reapply power) and allow the Base Station/SmartHub to come back online. Then make sure that you have the latest version of the Arlo iOS app and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Just wondering if you’re able to send me a reset token to link to HomeKit?
Tried and sat there for an hour with nothing.
Cheers
Scott
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
