- English
- Arlo Forum Discussions
- Partner Integrations
- Arlo Doorbell Calls, Alexa and IPad freezing and ...
Arlo Doorbell Calls, Alexa and IPad freezing and not connecting
Hey,
I have following Problem:
I have the possibiity to test 2 Arlo Wirefree Doorbells in different setups.
First one: One Doorbell, 2 Android phones, Alexa Show.
Overall working so far. Calls are coming and the Show shows a Live Feed when i ask Alexa. But the Problem here is: If Someone pushes the Bell then the Phones are ringing and Show telling me someone is at the door- if i ask Alexa to show me the stream -> it will load forever. When the calls are stopped i can ask Alexa again and its working. So technically its kinda useless. I can see a live feed when noone is at the door but if so i can't. Also tried a non stop live stream - if someone pushes the bell the video is stopped and alexa is kinda crashing.
Same with the other Setup: 2 Iphones 1 IPad 1 Doorbell
The Ipad is the Smart Home central station at the wall. The idea is if someone rings you can look at the Ipad. 2 Calls are coming on the Iphones and aswell on the Tablet but the same Problem. If i use the answer call on the Tablet it will load forever- afterwards its working again.
Any things i can try?
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
AppleTV
31 -
Samsung SmartThings
81 -
Security System
