Apple homekit can’t Connect
Hi
Never got Apple HomeKit to work with my Arlo setup. The Smart Hub shows up in Homekit and everything seems fine until I enter the HomeKit code and click next.
If I go though the Arlo app it just never stops saying “connecting to accessory”.
If I go through the Home app it’s saying “the accessory can’t be used by HomeKit”.
Anyone else having this issue or can give me some help? Seen a lot about a token reset that seems to work well for others but they all seem to have it worked before.
Using the latest iOS, Arlo app and firmware.
Thank you
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
