Apple Homekit token reset
Hi,
I need a Apple Homekit token reset after removing my two base stations.
SN(1): 5GP60A79A0580
SN(2): A0E2057KA198F
Thanks! 🙂
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Thank you.
I've tried to power cycle both base stations about ten times since your token reset, but still no luck. I'm still completely stuck on the "identifying" screen...
ssaa,
I've sent another token reset. Are you still experiencing the same issue?
I need a homekit token reset too but i can't figure out how to start a new post. SN 4R047877A1374. Can you help?
damonius,
Thank you, worked!
I need a homekit token reset too .
SN A6G2187WA00A1. Can you help me?
Maksigun,
Wow!!! It worked ! Thanks
Hi, Can I please get a token reset for apple HomeKit? VMB5000r6 SN: A6F32179A03BC Thx
I would also like a token reset so I can re-add my base station. Thank you.
Spatelnz, ArloUser195
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
