Apple Homekit token reset
  • 12 Replies
  • 3874 Views
  • 6 In Conversation
Retired_Member
Not applicable
Hi,
I need a Apple Homekit token reset after removing my two base stations.
SN(1): 5GP60A79A0580
SN(2): A0E2057KA198F
Thanks! 🙂
12 REPLIES 12
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Retired_Member
Not applicable
Thank you.
I've tried to power cycle both base stations about ten times since your token reset, but still no luck. I'm still completely stuck on the "identifying" screen...
ssaa,
I've sent another token reset. Are you still experiencing the same issue?
damonius
I need a homekit token reset too but i can't figure out how to start a new post. SN 4R047877A1374. Can you help?
damonius,
damonius
Thank you, worked!
Maksigun
I need a homekit token reset too .
SN A6G2187WA00A1. Can you help me?
Maksigun,
Maksigun
Wow!!! It worked ! Thanks
Spatelnz
Hi, Can I please get a token reset for apple HomeKit?  VMB5000r6 SN: A6F32179A03BC Thx
ArloUser195
I would also like a token reset so I can re-add my base station. Thank you.
Spatelnz, ArloUser195
