- English
- Arlo Forum Discussions
- Partner Integrations
- Apple HomeKit stuck at "Discovering your device. P...
Apple HomeKit stuck at "Discovering your device. Please wait
I've seen some responses about needing a token sent for this issue?
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Can I get a token as well … trying to add 5 cameras to HomeKit - the 5th Is the Arlo vid wireless doorbell - does anyone know if you can have 5 cams on HomeKit?
Pierreb77,
Please can I have a token reset also, I can’t add to HomeKit
BennRule,
All done! Thanks
I am having the same issue, may the token be reset on mine too please?
I’m having this issue as well. Can you send a token reset to my hub too
thanks
May I please get a toke reset as well. Trying to add my 3 cameras back to HomeKit
Thanks!
Kai4615, infinityends, brucelzy
Can I also please get token reset thanks
Can I get a token reset please?
ArloCanada, txtx1979
Thank you, that solved my issue.
Thanks token reset worked.
albifossa,
I have encountered the same issue, just stuck there
can you send me a token reset
thanks
Can I get a token to reset my base unit
mingming2468, Bobrown
I'm having the same issue, can i get a token reset please.
thais0n,
I am having the same issue. Can you please send a reset token.
Jeff
ripper64,
AppleTV
33 -
Samsung SmartThings
88 -
Security System
