- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Apple HomeKit stuck at "Discovering your devic...
I had HomeKit set up but then removed it because I was reorganizing things. Now when I try to add my base station again the app just gets stuck on "Discovering your device. Please wait." I saw this posted elsewhere for a different hub and support sent a token reset request which seemed to resolve the issue for others. Is that what I need here?
Hi aarondy90,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit
As detailed in other posts, I once was able to connect to HomeKit, and had to restore. Since then attempts to reconnect to HomeKit end up with a "Discovering your device..." blank screen. I understand that the problem can be solved by a reset token sent to the base station, but how do I request one?
Hi Inkblot007, Mvanwinkle, bartimaeus2001,
Hey aarondy90,
I've sent a token request to your base station again. If you're still having issues, contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
I am also unable to add Arlo to HomeKit, hanging on "discovering your device". May I please have "token resets" (whatever they are) for my two base stations?
Hi sharkkb8,
When I try to add my new ultra 2 base station to HomeKit I get the message that I can’t add it because it’s uncertified accessory, any help with that issue
Hi Gfayez76,
Thanks, it works now
I recently bought a 4 pack of Arlo Ultra. I can't get the App to find the devices, it just never finds any of the devices "Discovering your device. Please Wait". I'm very disappointed to have spent so much money on a product described as Homekit compatible. Rebooted a dozen times, uninstalled and reinstalled, and yet I can't get Homekit to connect. I've even put all the camera literal 2 inches away from the hub far away from anything that can interfere with the signal. Really sad I purchased the product.
Hello,
I'm suffering the same issue. What information do you need to send a new token?
Thx.
Hi Inkblot007, brabo72 and leimema,
Hi,
Can you send me the token also ?
My Base station can't work with homkit - i removed it from homekit but now it is stuck in 'wait...decting your .." in the app..
My station is: VMB4000r3 - firmware 1.16.4.3_3739_fbb05d3
Tx!
Can you send me a new token too? This seems to be a product issue. One for Twitter. I contacted the support with this issue and they never got back to me. Not a good service, let's hope the new Verisure service isn't so poor.
Hi MK_Flight,
Hi brabo72,
I have already sent you a token reset request yesterday to your base station which should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit
It works perfectly again! Big Tx! Can I do something to prevent this from happening or is this a server based thingy?
Maybe a quick other question 😜...i have bought a arlo doorbel aad1001... can this also work with homekit or not? (Homepod sound)
Grtz
Mk
Hey MK_Flight,
The Arlo Audio Doorbell (AAD1001) does not work with Apple HomeKit. You can see the full list of Arlo products that will work with Apple HomeKit: How do I connect my Arlo camera to Apple HomeKit?
Hi Paczada,
AppleTV
Samsung SmartThings
80 -
Security System
