Paramètres
Répondre
Statistiques de discussion
  • 1 réponse
  • 1684 visites
  • 0 compliments
  • 2 en conversation
Badour
que signifie le petit rond orange sur la roue « paramètres »?
1 RÉPONSE 1
It means that some setting needs to be reviewed and possibly adjusted.
If you go into the settings menu, you should see the same orange circle on one or more options there.
One common situation is that the system has detected the camera is in a different position, and is suggesting that you adjust the activity zones.
