what upload speed do I need for internet connection for security cameras videp to the cloud
Message 1 of 2
14,818
the minimum recommended speed is 1 Mb connection.
What are the minimum requirements for installing my Arlo system?
You will need the following to activate your Arlo Smart Home Security system:
- A computer or mobile device (iOS 7 or higher, Android or FireOS)
- The Arlo app
- A high-speed internet connection (minimum 1 Mbps upstream recommended)
- An available Ethernet port on your router
If you are using a PC, you also need a supported Internet browser. The following browsers are qualified to work with the Arlo web application:
- Internet Explorer 10 or higher
- Firefox 3.5 or higher
- Safari 3 or higher (Except on Windows and Linux)
- Chrome
To download the mobile app for your smartphone or tablet, visit the app store and search for “Arlo”.
Message 2 of 2
14,777
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
