what upload speed do I need for internet connection for security cameras videp to the cloud
  • 1 Reply
  • 14672 Views
presleysusan
the minimum recommended speed is 1 Mb connection.
What are the minimum requirements for installing my Arlo system?
You will need the following to activate your Arlo Smart Home Security system:
  • A computer or mobile device (iOS 7 or higher, Android or FireOS)
  • The Arlo app
  • A high-speed internet connection (minimum 1 Mbps upstream recommended)
  • An available Ethernet port on your router
If you are using a PC, you also need a supported Internet browser. The following browsers are qualified to work with the Arlo web application:
  • Internet Explorer 10 or higher
  • Firefox 3.5 or higher
  • Safari 3 or higher (Except on Windows and Linux)
  • Chrome
To download the mobile app for your smartphone or tablet, visit the app store and search for “Arlo”.
