rules not showing up
  • 13 Replies
  • 22225 Views
  • 6 In Conversation
mature4ever
I have four cameras installed but when i go to rules nothing shows up. It keep spinning for hours never showing me the rules.
13 REPLIES 13
are you working on a PC, IOS, or Android system?
Rudy
my rules were showing up, but i couldn't access the timezone window
Rudy
Tom this is related to the connectivity issue we are all experiencing, if he tries back later, viola I bet he sees his rules
mature4ever
Im on an android
mature4ever
I actually deleted a rule but since then i cannot add a rule. Nothing shows up but the spinning circle as if its trying to open the settings
mature4ever
Any suggestions on getting the rules to show up?
Since you're on Android, you can try uninstalling the app and reinstall - that sometimes removes glitches. What happens when you use a web browser?
BrianL
Hi mature4ever,
I have tested this on an Android phone 5.0 Lollipop with Arlo app version 1.9.0_9413 and encountered the same problem. To fix this problem, use a computer and access your Arlo account through https://arlo.netgear.com/#/login and create a rule. Once done, you may now create and configure rules using your mobile phone or tablet (iOS and Android). I will have this problem reported and keep you posted.
Kind regards,
BrianL
Arlo Team
molson42
Hello,
I am having trouble with rules; both on the android app and desktop.  Both just load and load and load but never load.
Please help!
Chris
Have you tried logging out and back into the Arlo servers or using a different browser? The fact that both the app and browser have issues may point to other issues such as ports needing to be opened on the router but try these first. Also, try the mobile device on cell rather than WiFi.
molson42
Yes, I tried both.  What ports specifically need to be opened?
80 and 443 need to be open.  It could also be computer firewall or antivirus settings.
molson42
*** SOLVED ***
I had everything configured correctly; I ended up deactivating the base station, adding the same base station back, and factory resetting the base station.
Everything now works great!
Thank you for your help!
Chris
