"Experimental/Advanced" setting at bottom of Arlo app IOS Settings
If you go to the Settings of the Arlo app for IOS, there is a setting at the bottom that is switched off by default, that says "Experimental/Advanced". Of course, I am really curious what turning this on will do (or not do). : )
Anyone?
Thanks!
Never noticed... good find.
Turned it on for 5 mins, played with system, didn't see any difference
Message 2 of 2
1,739
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
