  • 5216 Views
Jester_aero
.Heads up for people changing motion sensitivity. dont change in the motion detection test in the app in camera setting the true settings are under armed mode.
steve_t
Master Master
The motion sensitivity setting is in the RULE for the particular camera in the MODE that you're using. Armed is one of the modes you can use and you can customise it but you can also create other modes with more than one rule per camera
steve_t
Master Master
fkme
evrytime i exit and recheck it defaults back to 80
there appears to be no option to save once you change the setting.
the reason i want at 100 is becasue after testing the detection is only activating after i leave the area so you only see me walking away not approching the detection area which is useless.
Caryjay
After you move the sensitivity to 100, click on BACK then click on SAVE to keep sensitivity at the new 100 setting.
