im having hardtime see the star its white it used to be yellow.
pcuser12345,
The favorites star is yellow on both the web client and Android app. It is white only on the iOS app.
If you are having trouble seeing the star, try using the web client.
Message 2 of 3
2,599
Using the web client doesn't address or fix the problem on iOS. The iOS app needs better feedback that the star has been tapped. The app appears to be broken when you tap and tap on the star, but nothing seems to be happening.
Message 3 of 3
2,556
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
