how to make the system record video longer than 10 second
  • 1323 Views
lzander1
I was hoping someone might be able to point me in the right direction. I just purchased and install my Arlo Pro base station and cameras, over the last day I have been trying to find out how to make the system record video longer than 10 seconds. I have googled it and looked in faq and the settings don't allow to edit the video length. Any help would be appreciated.
Thank you!
Streak2
Master Master
You need to go to Mode, then armed right arrow, select a camera edit , then record video right arrow.
You will see a slider to change the duration.
Don't forget to click back and then save.
Streak2
Master Master
lzander1
Thank you,
You have to hit save it will take you back then hit save again. It worked and again thank you for your quick reply!!!
Streak2
Master Master
Well done for getting it sirted out.
The user interface is different depending on what app you are using.
The instructions I mentioned are for when using the browser https://arlo.netgear.com/
When doing the same using my Android app there is in fact a save button on the video setting screen.
Hopefully Netgear will standardize all of these to avoid further confusion.
