Won't let me join Premier so I can add more cams
  • 1 Reply
  • 623 Views
DVY28
Everytime I try and join one of the deals to add more than six Cams it won't let me. How do I join Premeir or any other for that matter to ADD more than six Cams?
Regards
Bill
What do you mean by deal? There have been 6 camera sets (don't know if any are currently available) but that's different from adding cameras. You should be able to add cameras on any plan but you'll only be able to utilize various numbers of them depending on your plan , 5 for the free plan. That is, you could have 6 or more on your free plan which only supports 5 but you'll have to pick one to be inactive.
If you really want 6 or more, there are various strategies such as multiple free accounts (using different email addresses) with only 5 on each one or subscribe to a paid plan using Settings, Subscription to sign up.
In any event, you can sync more cameras - it's access to them that would be the issue.
