can the signal between base station and cams be blocked and if so how do I stop that?
  • 6 Replies
  • 2223 Views
Jo
I installed this system for a specific reason to keep know "problems" from happening or to prove who was responsible.  I have battled through the set up and got it running perfectly, now when the suspected culprit passes the camera it malfunctions. I  suspect a signal blocker how do I prevent the signal from being blocked?
6 REPLIES 6
If it's interference, there's no way to fix that.  You'd need a wired system to prevent that sort of problem.  You could try to locate the base station closer for a stronger signal or reposition the camera to place it further from the perp but if it's being jammed, all bets could be off.
Jo
Thank you for your feed back.
Jo
Anyone out there have anything?
I think my post above is the best you'll get.  How can you keep a signal from being blocked? Only buy using a technology that can't be blocked.
As mentioned, with the info given, there's not much to reply to... it will either work or it won't.
Not disbelieving you , but in my experience from this type of work, most times people think a "blocking" device is being used on them, it's usu another form of interference.
If you need it to work 100% and it isn't maybe you should consider a hard wired camera.
Jo
ThanksSmiley Very Happy
