arlo android app 2.0.0_11298 doesn't show all library videos
  • 5 Replies
  • 1543 Views
captnpops
The new anroid app doesn't access the complete library while PC access does... is there something to adjust?
as noted: arlo android app 2.0.0_11298 running on LG G4 android version 5.1, doesn't show all library videos(no filters selected)
5 REPLIES 5
new android app is 2.0.1-11309
captnpops
Thanks, I have uninstalled reinstalled the Arlo App from the play store twice, and when I open it..'a new version of the Arlo app is available', gives me an icon to update, click on update and back to click on open and tells me there's a new app... so I can only run the old app by saying don't update..
Is there some other way to get 2.0.1-11309.. thks
Sorry... no other idea where to get it from... My older OS 4.4 said there was an update and I let it do it thru the store.. installed no problem.
Prob will have to wait till after NYr day
captnpops,
Were you able to get the latest version of the android app installed? If so, are you still experiencing this issue?
captnpops
yes, I've got _11309.. the current app and no, there is not a solution. I have had a case open on the problem and have seen many posts with the same problem.. the person opening the case noted that it would be combined with many others noting the same problem
