android app username and password
  • 2841 Views
myukon
Are alternate credentials required for the mobile (android) app? The username and password that I use at the web portal fail on my mobile.
Same ID/password is used for access on mutli devices.... check to verify you didn't miss a capital as the pw can be case sensitive.
HollyQ
HI, I just bought a new Motorola Droid Razor and can't get the netgear account icon on my phone.  I entr my password and it says it's incorrect.  Can anyone help?  thanks,  Holly
Maybe misunderstood this...
First you have to go to the android store and d/l the Arlo app from there ( your pw/user is prob diff here, it would prob be your phones pw )
Once the app is installed, you same user/pw from other devices like your computer to log into the app
