  • 1 Reply
  • 1521 Views
casa1295
under mode activate / deactivate camera I accidently deleted the mode deactive camera - no all my cameras are running all the time and I can put back the option camera deactivate under mode again.
Somebody can help how to eventually reset all my parameters to intial setup - deleting the app shows the old individual parameters again ...
Thank you Peter
The easiest thing is to do a factory reset which will require you to start over with syncing cameras and setting up rules and modes.  The default modes of all motion on/off will be recreated.  If you want to do this, use the reset hole next to the power switch and hold the sync button on the side of the base at the same time until the front LEDs start flashing.
