Why cant i adjust my motion detection length
  • 6 Replies
  • 2202 Views
  • 5 In Conversation
src81
When i go into my arlo app it will not let me adjust my motion detection length, its like its frozen, does anyone know how to fix this?, emailed arlo several times, no reply.they need a update quick
6 REPLIES 6
FLhome
I had the same question but I found an article that helped on Arlo's website.
 At the top of the homepage, click Support > Arlo Community > Arlo Knowledge base > Go to page 4.  Look for the article "How do I adjust Arlo video recording length?"  Follow the directions on this page.
And if your using an app like IOS, adjust on the PC browser ( ios app has been glitchy ) at   https://arlo.netgear.com/
Also when you do adjust , the SAVE is on the previous page at bottom, so you have to use the 'back' in the upper left corner
Consider uninstalling the Arlo mobile app and install a fresh version from the app store. Do you still see the same behavior?
src81
The uninstalling and reinstalling does nothing still, just hope arlo comes out for an update on ios
Use a browser for a workaround at this time.
src81
Still the same thing, nothing happens when reinstalling the app, and the option of recording length goes away on the app very often, to make matters worse!!!!, the recording box will be unchecked even though i chose to record the day before!, arlo has to get it together before they lose customers!!, paid too much money for this system for this to keep occuring!!!
