Where is "My Devices" within Android App?
  • 5 Replies
  • 2626 Views
Liem
When you are on Android app, under Settings, do you see My Devices there?
I need to figure out how to see the Battery level (percentage) when using Android App.
I do see this info from a laptop, but not on my phone or tablet.
BTW: I had OEM Battery (Panasonic CR123A) that came with Arlo, after 10 days of experiment with heavy usage, battery went down to 62% and only 2.98 volt left. I just installed 4 fully charged EdisonBright RCR123A, battery level is now 100%. Will see in a few days if those batteries are good or not.
Liem
jguerdat wrote:
That's not the standard view.  You're either using a very old app (current version is 2.1.3) or maybe you haven't completed the account setup yet - I note the Confirm Email notification for Profile.
I did the Email verification, also uninstalled and reinstalled Arlo app a few times, same result.
My Arlo App version is 2.1.3_14043 Release date 8/15/16.
This is also happenning on my Google Nexus tablet.
Thinking about this, I figured out only the PRIMARY account is able to see "My Devices" under Settings. All of the other "Friend" users do not have this feature.
5 REPLIES 5
lifebeginsafter
once app comes on, go to upper right corner, click on 3 dots that are verticle, settings, my devices, click on camera name, then you should see percentage of battery usage. It this way on my phone.
Liem
Hmmmm, it's not there.
Liem
Yup. Glad you figgered it out!
