What does the sun icon do?
While watching live, there is a sun icon with adjusting slide. It doesn't seem to do anythig. What's it for?
Message 1 of 3
20,622
The "sun" icon changes the iris level for a bright room or dark room....
Exp. a sunny room, turn the "sun" down, and hit the save ( check mark ) before exit. You'll see the brightness of the image change.
I think there are only 4 settings on the slider bar.
Message 2 of 3
20,573
And don't forget to click on the green checkmark in a circle after you make a brightness adjustment or the change won't take effect.
Message 3 of 3
20,488
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
