What do green and gray modes in Scheduler mean?
  • 1 Reply
  • 11147 Views
Schorschi
Prodigy
Prodigy
This isn't a question specifically regarding the app(s), as it applies to the web UI as well:
What does the color of a mode in the Scheduler signify? Green and gray are used, but I haven't figured out a pattern as to which modes are gray and which are green.
Anyone?
laurenc
Luminary
Luminary
Hi Schorschi
The colors for the modes don't necessarily signify anything, but the colors provides a visual break to differentiate the modes when setting a schedule. Initially, the two default modes for All motion on= green and All motion off = gray. If you add more modes, the next mode will be green, and then the 4th mode will be gray (see below image).
However, the color for one mode should be the same color throughout the entire schedule. For example with my below image, all times you set All motion on in the schedule, it should always be green.
I hope this helps!
Lauren
Arlo Team
