Viewing images from two base stations/accounts
  • 4 Replies
  • 6541 Views
edandjake
I'm trying to figure out how to view my four cameras located on two base stations.  The solution posted works for PC viewing-how about on the iPhone?  Also, can a 'friend' be registered on two accounts and view cameras on both (potential workaround)?
edandjake,
When adding the friend to the account did you grant them rights to view camera & associated images?  Once the friend account has been accepted, if you click on the name of the friend you will have options to allow them to view cameras.
Make sure you see the green check marks and be sure to save.  Do this on both accounts and you should see all four camera feeds from both accounts.
Hope this helps!
edandjake,
If I follow your question correctly, you have base station A with 2 cameras attached and base station B also with 2 cameras attached and you're wanting to view all cameras from stations A and B collectively on each station.  You could, as you suggest, friend the account associated with station A with station B and vice versa.  This would allow streaming all cameras on both stations.  This should also be true for the iPhone app.
Alternatively, when subscribing to the Elite Plan you can manage up to 3 base stations on a single account.
Let me know if this helps!
edandjake
Thanks--yes, that's my question.  I tried your suggestion but when logging into either account, I can only see the two cameras for the account I'm logged in to.  Would it work to 'friend' a third account that does not have a primary system?  Thanks!
edandjake,
Hope this helps!
edandjake
Perfect!  Neither account had gone through the whole 'accepting' process.  The cameras had been checked but it wasn't enough.  Once I accepted both invitations from the accounts on the PC, all four cameras are visible from either account.  Very helpful!  Thanks so much!!
