VMB3000 writing a rule
  • 4 Replies
  • 1954 Views
Dropshot
How does one write a rule that will keep 3 or 4 cameras on and one off?
Thanks,
Mark
Dropshot wrote:
Thank you Tom! That did the trick.
maybe you can help me with scheduling? I can't seem to do any scheduling at night. For example, from 10 pm. to 6 am. For some reason it won't let me do it.
Thanks,
Mark
Easy Peasy.... It's a design of the program NOT to run thru Midnight ( prob saves trouble with dates )
So, when your time slot goes thru midnight, break it into 2 parts.   In your case go from 10pm to 1159pm and restart / pickup at 1200am to 6am ( with second half )
read this;  https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-create-and-define-Modes-and-Rules/ta-p...
Then when following the steps, add the first three cameras and leave out the last.  Any camera NOT in the Mode will  be OFF when the mode is active.
Dropshot
Thanks,
Mark
Thanks,
Mark
Dropshot
Thank you! Thank you!
This community is great!!
