Turning motion detection off for a short term
  • 2 Replies
  • 2355 Views
glass2181
We have 5 cameras set up.  There are 2 in the back yard which when we are working in the garden or mowing grass are activated repeatedly.  Is there a way to turn these 2 cameras off when my husband is spending the day in the yard.  It seems pointless to use battery power as they are repeatedly activated.
Geoff
Luminary
Luminary
Yes you can.
Just go into 'settings', then 'mode' and you can select each camera to turn it off.
I do that when there is washing on the line in my back garden which keeps activating the camera.
Don't forget to click 'SAVE' after each process.
Hope that helps
Turn all the cameras off or,
Create a new MODE with those 2 cameras OFF and the rest of the cameras ON.....
SETTINGS  / MODE /  ADD / name Mode to YARD WORK ( or similar ), toggle all cameras on (green check mark) except the yard cams ( Black check mark).
SAVE upon exit
 when activated mode YARD WORK,  those back 2 cams witll be off, the rest on
