This is how you fix your notification issue
  • 4 Replies
  • 2366 Views
BigBrother
IOS app
On the latest update for the Arlo App
1. Go into your modes and press the edit pencil.
2. select a camera by pressing the pencil icon on the right
3. in the alert section at the bottom check push notification
That should do it.
Seems the new update added this feature which may have rendered your app lame.
I think this check box should have been on be default as I have all kinds of people showing up at my gate for a party and I had no idea.
Have you checked your modes to see if the notifications are activated? The update turned them off with the switch from global to camera-based.
 BTW, this has been asked and answered many times here.
Spridell
I dont see anywhere on either the Desktop portal or on my Android app where it says notifications.
Before the update they were there but now they are no longer there.
No option ANYWHERE to edit notifications.
As noted in many, many posts here, they ARE there, just in a different place. Use the Mode tab, select your system, edit your modes (not schedule) and set your notifications.
Spridell
After digging I have found the settings.
Thank you
Should of made it easier to find.  Was much much better the old way.
