Temperature Range
I live in a northern climate. The temp outside will get to -30
Fahrenheit.
I moved my cameras indoors but found out that motion detection doesn't work through glass. What are my options??
Message 1 of 3
2,808
Arlo operation temps are (-10° C to 50° C) -30C is well outside that specification, battery life in that climate would aslo be subpar. Protect you investment and keep them indoors until the temps change.
Message 2 of 3
2,803
You might consider the new Q cameras which will detect through glass but you'll need outdoor lighting since the built-in IR illuminators will reflect off the glass.
Message 3 of 3
2,794
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
