  • 7 Replies
  • 6437 Views
  • 4 Likes
  • 5 In Conversation
cvxdoc
How do I turn of email notifications. I receive too many when motion is detected.
It's set in your modes.  Mode tab, click on your base and edit any modes you use to disable email notifications. Be sure to save your new settings.
7 REPLIES 7
cvxdoc,
For detailed instructions, see here: How do I turn on/off email notifications?
cvxdoc
Thank you very much. Emails have been  disabled per your instruction. Am now happy with an empty email box.
KCV
So this can't be done from the app right? Or am I missing something?
Yes, it can be done via the app. It's just that you need to change the settings in any modes/rules found in the Modes tab.
Adam44444125
The tricky part on my app is that I had to edit a mode that was not highlighted. I am using "Geofencing" but I had to edit the "Armed" mode to deselect email notifications. I also had the option to turn off email notifications but keep push notifications. Exactly what I wanted.
Yup.  GF and Schedule aren't modes - they're how you can use your modes.
