  • 3375 Views
  • 2 Likes
leafBuilder
Is there a feature in Arlo's software that allows its users to track when the last logon/logoff was initiated, and/or a feature that would indicate whether or not a particular camera, or any cluster of cameras had been deactivated, or timed-out?
Thanks!
John
No... the only logs created that are visible at at the far end..the techs can see cams/bases on-off and prob log in times... plus other data.
JPC
Prodigy
Prodigy
 At this point, You own the Physical System but the back-end (Firmware/Software) part.. Netgear owns it.. But you can put your request on the link below and hopefully they'll implement it..
https://community.netgear.com/t5/ideas/v2/ideaexchangepage/blog-id/arlo-idea-exchange/tab/most-recen...
leafBuilder
Thanks!
