Selectively turn off camera specific PUSH notification
  • 19 Replies
  • 52554 Views
  • 27 Likes
  • 15 In Conversation
chamaway
Hello group...
Love my Arlo system... have five cameras now and works great...
Only ONE real annoyance... I have found where I can turn off email notification by camera (rules) but cannot figure out where to turn off App Push Notifcation by camera... for example, I want to be notified by a push on the app when one of the cameras detects motion, but it sends me when any of the cameras do that are set to record on motion...
So when someone walks up the drive I get TWO alerts... really want ONE alert but both cameras to record...
Any ideas??? Thanks!!!
19 REPLIES 19
You can either turn on the Push notifications ( IOS; setting, notify, arlo app ) or off in the App...
Don't believe you can singlely turn off the Push for One camera as it's a sytem on or off.
( may be wrong, but don't see it in the ipad )
chamaway
Seems like a lack of functionality... if you can selectively turn off emails your should be allowed to selectively turn off push notifcations???
socal92201
I have the same issue and wish there was a fix.
pr7
Agree completely. Hopefully they'll put a mod out for that in an upcoming revision.
Sshereec
Agree, we would like to only be notified by push notification for one camera and let the other three record without a notification.
chamaway
Arlo... how do we add this to the concern front???
Seems like what should be an easy fix... just allow us to have record without alert...
Help... thanks!
Dany37
I'd like to have the solution, too !!!!
check and see if its a listed want and if so add kudos...
 https://community.netgear.com/t5/Arlo-Idea-Exchange/idb-p/arlo-idea-exchange
if not there, then add as  request, more likely to come to fruition with more requests/kudos
Showguy
Virtuoso
Virtuoso
There is a funky work around for your issue if you don't mind getting a text message instead of an alert.
1- turn push alerts off.
2- go to the camera you want to receive an alert and follow the instructions below.
To receive text message notifications instead of email notifications, you must convert a phone number into an email address. This is useful if you use a feature phone (as opposed to a smartphone) because feature phones are usually capable of sending and receiving text messages.
Before you convert a phone number into an email address, you need the email-to-text message format for your mobile phone service provider. Refer to the following list of email-to-text message formats by provider:
Alltel. [email protected]
AT&T. [email protected]
Cingular. [email protected]
Metro PCS. [email protected]
Nextel. [email protected]
Powertel. [email protected]
Sprint. [email protected]
SunCom. [email protected]
T-Mobile. [email protected]
US Cellular. [email protected]
Verizon. [email protected]
Virgin Mobile. [email protected]
Check with your mobile phone service provider to confirm the format.
To receive text message notifications from your Arlo camera, complete the following steps:
Don12
I agree. Nothing more irritating than family of 5 home and moving about. Constant alarm of motion detected. Ding ding ding ding. Needs to be functional before best buy return period or I WILL return it
Ghepburn
Someone within Netgear must be remunerated to look after these aspects of the product. I myself realized that I needed such a function before I even bought the product and that is how I ended on this blog. Sad to find out that the function is lacking, that the programmers were not astute enough to think about it in the first place, and, above all, that they are not bothering to rectify ……. On a high note it is to comforting to understand that there is always a “gap in the market”…..
mkrieger
I agree - not being able to turn off push notification per camera is a real annoyance. It seems that it would be a very simple fix - just have an option to send push notifications in rules like there is for email.
Netgear/Arlo team - is this feature planned any time soon?
mkrieger,
Welcome to the community! I don't have any information on the release of more push notification customization options. I encourage you to visit the Arlo Idea Exchange and kudo existing or post there requesting this feature.
Regards,
jtarlo23
Hi,
Try logging into arlo.netgear.com on your computer.  Select Mode--> Armed--> pick a camera--> Edit--> uncheck push notification.  You select which camera to turn off the push notification.
It worked for me, I was able to selectively turn off my cameras; especially ones I have in the living room which are high traffic areas.
best of luck!
amitchell
this works!! thank you 🙂
amitchell
actually didn't work completely - set to do Nothing and it still sends alerts - Save is not enabled when i try to deselect all options
apprecite the tip and hope Netgear fixes this soon
Baypilot
This is a standard feature on other security and video surveillance systems, zone ignore, I live on a busy alley, I don't need an alert every time someone walks by, but I do want the the recordings
sdyarnell
Re-igniting this thread. My dog is tripping up multiple of my cameras very frequently, and I do not want those notificaitons. I only want the recordings to occur.
I have messed with the motion sensing sensitivity for both cameras, and I still get a lot of notifications even at 10%. I am worried going too low may cause it to barely record at all.
I need control of these notificaitons.
sdyarnell
After actually looking in the app, I can apparently control this.
I have a different rule for each of my cameras. I just disabled push notificaitons for the rule.
Hope this helps someone, as I found this thread on google before finding anything that helps.
