  • 4 Replies
  • 1594 Views
Retired_Member
Not applicable
"If you log out of the Arlo app on your smartphone or mobile device, you will stop receiving push notifications." I don't understand the technicalities of apps but it means that the security of your Arlo system when in operation is therefore dependant on your smartphones security. Have I got this right - if you lose your phone or it is stolen you have to rely on its security to stop access to your cameras and library.
Yes , you have to keep the app open on the phone device to get pushes... But not emails.
Also, yes the phones passcode is the only thing stopping someone if your phone is stolen. Most phones have pretty good passcode levels and with iOS u can lock or clear your phone if stolen/ lost
Not to mention, just go to any other device and change the Arlo password.
Nope, there's always the email notifications and web access.
Retired_Member
Not applicable
Thanks for the response jguerdat. I'm sorry I didn't make it very clear but my question/statement relates more to having to leave the Arlo app open when the cameras are in use. If your phone is stolen or lost then the person who steals or finds it only needs to get past your phone's passcode to be able to  access your cameras. Not understanding how apps work, what is the point then of having a secure Arlo login ?
TomMac wrote:
Also, yes the phones passcode is the only thing stopping someone if your phone is stolen. Most phones have pretty good passcode levels and with iOS u can lock or clear your phone if stolen/ lost.
You can do the same with Android, depending on version and/or apps.  Use Google's Device Manager app to set up location monitoring and deactivation capabilities.  It's also accessible through the Google page https://www.google.com/android/devicemanager
