Saving Videos
  • 4 Replies
  • 3442 Views
KMKM
Hi,
I have the basic subscription whereby videos are recorded on the cloud (up to 1GB) for 7 days.
If there is a video I want to keep permanently forever how can I transfer that to my PC? At the moment all I know how to do is to send a link message to myself which when you click on the link directs you to an Arlo site and allows you to view for 24hours.
Many thanks for your help
KMKM
I am sorry - I have just found out.
For anyone who is unsure, you just login via the internet you want to download onto. Select the video and there is a download button.
KMKM
rxchristina
When I select the download button, it starts to download and then a notification on the top says "user denied"
Please help!
Thanks!
Please help!
Thanks!
Are you using an ipad/iphone?   if so. you must allow the app access to the library for saving files ( settings/arlo app/permissions )
rxchristina
Thank you!
It worked 🙂 and yes, I have an iPhone.
But under settings/Arlo app, I had to turn on "photo"
After downloading the video, I noticed that it does not play automatically in photo/video on iPhone when I press the play button. Rather, I had to manually "drag" the video 😞
But that's ok...at least I have a saved version of the recording.
Thanks again!
