Running Rules created in (New) Mode on schedule
  • 4 Replies
  • 1929 Views
Hula_Rock
Prodigy Prodigy
Prodigy
When I thought I had this system figured out ........
So,  I created a new Mode, lets call it "Custom 1".  In that new Mode I create 5 rules: (Motion A / Record B), (Motion B / Record A), (Motion A / Record A), (Motion B / Record B), and (Motion C / Record C).
Question:  How do I get the new Mode "Custom 1" to run on a SCHEDULE?  is it possible?  am I missing something?
The default "SCHEDULE" only lets you edit times and there is no way to add rules to it.
Hula_Rock
Prodigy Prodigy
Prodigy
Hula_Rock
Prodigy Prodigy
Prodigy
found it .....
montyi
I don't understand your solution. I would like to have one camera actavate another using the schedule mode.
You have to remember... the schedule just turns ON/OFF a mode AND only one Mode can be active at a time.
It's the mode that actually does the work and decides what cameras are active and how.
So you write a new MODE where Cam A senses and makes Cam B record.  Put that Mode into the schedule when wanted
montyi
thanks, when I added the mode to schedule, with the +Add, it chanced the color to blue so I think I'm OK.
