Rules - ability to use other camera motion detectors
  • 1 Reply
  • 1253 Views
TBone14
I have an Arlo camera placed behind a window. the problem is that the motion detection does not work. I'd love to have the ability to creat a rule that would allow me to start recording if the motion sensor on another camera was triggered.
You can do that already... Or use a Q camera that does work thru glass.
Tho the Arlos do not sense thru glass, you can use another Arlo to triggger record.
Example; 2 cameras one outside, one inside.
set up a custom mode as follows
When outside detects motion, record on inside
to take it a step futher; use two rules in a custom mode
Outside cam detects, outside cam records
Outside cam detects, inside cam records
(so both get turned on)
read this ; https://community.netgear.com/t5/Arlo-Knowledge-Base/What-are-modes-and-rules-and-how-does-Arlo-use-...
