PC not able to log in
  • 3009 Views
Rickster61
I just want to say I just had a pleasant experience with support. I was not able to log in with a PC but I could with androids. It turns out that there was a setting that needed to be changed in my Bitdefender Total Security 2015. The scan SSL btton had to be turned off and then add arlo.netgear.com to the whitelist. All is well now.
The_Flyguy
I had the exact same problem, and this worked for me as well.  I just changed security suites, and am new to both Arlo and Bitdefender.  I followed Rickster61's instructions and it worked.  The "Scan SSL" button is under:  Protection... Web Protection... in the Bitdefender Total Security 2015 version.
Thank you!  Thank you!!
Fly
Rickster61,
I am glad to hear you had a pleasant experience! This is great information that could possibly help other community members that may be experiencing a similar issue. Thank you for posting the feedback!
Rob1963
 Thanks for this.   I was having the same issue in that I could access my cameras with my iphone, but not my pc.    I also have Bitdefender on my PC.  I made these changes and, so far, it seems to have worked.
The_Flyguy
Fly
