  • 5 Replies
  • 21561 Views
  • 2 Likes
CarmineL
Motion detection appears to become disabled when viewing live mode of a camera.  No alerts are received, no video gets recorded.
5 REPLIES 5
If your LIVE viewing, you can always just toggle record on  ( round button, top of view )
Lonnie
The problem that I ran into with this is that if you look away or something distracts you while LIVE viewing, you miss the action. Sometimes I even view a few cameras at once. If I notice something on one camera, I watch it. Something else could be happening on a different camera. It should still record even when live viewing based upon the rules/mode that is currently set.
I don't know if this is the place to put suggestions to the Arlo/Netgear team but if not, could you please direct me to that location so that I can add this to their list.
I understand what you want... but also i would keep in mind that these cams are not meant to stream 24/7 due to battery limitations.
The best place to post your requests is here;
https://community.netgear.com/t5/Arlo-Idea-Exchange/idb-p/arlo-idea-exchange
more kudos given, the better chance of coming to fruition.
Lonnie
Thank you for your response. I understand it is not designed to watch 24/7 and I don't but sometimes I log in to see if anything has changed that didn't get captured. I figured out what the pause button is for and will start to use that when switching between cameras to prevent the loss of video.
I was wondering if a guest (friend) is viewing live, will it still record motion? What if that guest/friend has admin rights? Does that change anything?
You can control the level of rights given to a friend... ovb if they have admin rights they can change almost anything.
